clear counters cfm segment
clear counters cfm segment segment_name
Description
This command clears both frame-delay and frame-loss information for segment with given segment name.
Syntax Description
segment_name
An alpha numeric string identifying the segment name.
Default
N/A.
Usage Guidelines
Use this command to clear both frame-delay and frame-loss information for segment with given segment name.
# clear co cfm seg cs2
# sho cfm seg cs2
CFM Segment Name                : cs2
Domain Name                     : dom1
Association                     : a2
MD Level                        : 1
Destination MAC                 : 00:04:96:52:a7:38
Frame Delay:
DMM Transmission             : In Progress
Transmission Mode            : On Demand
Total Frames to be sent      : 45
Frames Transmitted           : 0
Pending Frames               : 40
Frames Received              : 0
DMM Tx Interval              : 10 secs
DMR Rx Timeout               : 50 msec
Alarm Threshold              : 10 %
Clear Threshold              : 95 %
Measurement Window Size      : 60
Class of Service             : 6
Tx Start Time                : None
Min Delay                    : None
Max Delay                    : None
Last Alarm Time              : None
Alarm State                  : None
Lost Frames                  : 0
Frame Loss:
LMM Tx Interval              : 10 secs
SES Threshold                : 1.000000e-02
Consecutive Available Count  : 4
Measurement Window Size      : 1200
Total Configured MEPs        : 1
Total Active MEPs            : 1
MEP ID                    : 2
LMM Transmission          : In Progress
Pending Frames            : 40
Frames Received           : 0
Availability Status       : Idle
Unavailability Start Time : None
Unavailability End Time   : None
Press <SPACE> to continue or <Q> to quit:
Total Configured Segments       : 11
Total Active Segments           : 11
This command was first available in ExtremeXOS 15.1.
Platform Availability
